Key buzz reminder wouldn't stop. fixed that now blower motor won't work. Should I replace the blower motor?
Nov 18, 2008 at 3:58 PM
✓Experienced Mechanic
Hi:
Check for power to the motor. If you're getting it, replace the motor. Make sure the motor is getting a god ground. If there is no power, move back to the blower motor resister. Check for power there. If power is there and not to the motor, replace the resister. If no power to the resister, check the switch itself.
