The heater fan seems to be dead. I can't locate it to replace. Can you tell me where to find it?
Sep 21, 2009 at 9:54 AM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
The blower motor is located on right side of firewall -if you power up the motor direct from the battery and it turns on then its not the problem -could be a fuse , blower motor relay, resistor and blower motor control switch
Sep 21, 2009 at 12:16 PM
IRABIKE
MEMBER
Thanks, but still unsure of location. Can I get to it from inside the car on the passenger side or do I have to go in from under the hood?
