1995 Ford Aerostar won't start
JANUARY1
  • 1995 FORD AEROSTAR
  • 6 CYL
  • FWD
  • 300,000 MILES
I did a engine wash now my vehicle won't start even though I jump starrted still no response only cliking sound
Friday, January 16th, 2009 AT 12:35 PM
No crank-check and test the battery connection/starter/starter relay/transmissiion range switch and ignition switch
Friday, January 16th, 2009 AT 12:39 PM
JANUARY1
I have tested ther battery connection, plz explain where I can fiind starter/starter relay/transmissiion range switch and ignition switch. Thank you 4 ur time
Friday, January 16th, 2009 AT 12:48 PM
You need a repair manual for procedures/ guidelines-If you follow the battery positive cable the other way it will atke to the starter relay after that straight to the starter-The TRS is on the transmission
Test the battery open voltage should be 12.4 volts or better
Friday, January 16th, 2009 AT 12:54 PM
JANUARY1
Thank u 4 the response, where can I get the repair manual? How much is it?
Friday, January 16th, 2009 AT 1:04 PM
Auto parts store-runs about $15.00
Friday, January 16th, 2009 AT 1:56 PM
