1994 Ford Aerostar It won't start
HJPETERS
  • 1994 FORD AEROSTAR
  • 6 CYL
  • 90,000 MILES
We have had trouble starting the van since we bought it. It would turn over, but not fire up. Now it's not even trying to turn over. We hear a click and then nothing.
Friday, April 9th, 2010 AT 11:32 AM
Load test the battery and make sure the connections are good then do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, April 9th, 2010 AT 3:58 PM
