1993 Ford Aerostar
ZSU
  • 1993 FORD AEROSTAR
Electrical problem
1993 Ford Aerostar 6 cyl Two Wheel Drive Automatic
my oil pressure gauge always stays in the same spot when running(never varies). My check oil light will come on at about 1 qt. Low, I guess my question is. Is the pressure ga. Electrical?
Sunday, August 15th, 2010 AT 5:40 PM
Check the oil pressure with a mechanical gauge, if normal replace the oil pressure switch could also be the gauge/wiring problem. If abnormal could mean oil pump and engine bearing.
Sunday, August 15th, 2010 AT 7:51 PM
