1993 Ford Aerostar
JOHN HOLDERFIELD
  • 1993 FORD AEROSTAR
1993 Ford Aerostar 10000+ miles
The upper radiator hose bust, leaving about a 6inch "wound" in the hose. What would have caused such an explosive rupture? Is THAT much pressure normal? Will replacing the hose solve my problem, or is the same thing going to happen to my new hose?
Saturday, January 17th, 2009 AT 8:45 AM
  • 109,885 POSTS
Hi:
It is normal for pressure to build in the cooling system. However, you may want to have the radiator cap tested to make sure it releases pressure when it should. If it is good (or you replace it. They are cheap) you should have no problem with the new hose.
Was the one that broke original?
Sunday, February 8th, 2009 AT 1:37 PM
