1993 Ford Aerostar water pump
COONS39
Engine Cooling problem
1993 Ford Aerostar 6 cyl Two Wheel Drive Automatic
is the water pump on a 93 and 95 the same wat happens when it goes out?
Feb 3, 2009 at 9:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, '93 and '95 water pump is interchangeable. Symptoms of fautly water pump are leaking coolant from pump, very loud noises from pump and possible overheating of engine.
Thanks for using 2CarPros.com!
Feb 3, 2009 at 4:38 PM
