I'm on my second Aerostar and on both the whole coolant system has gotten eventually replaced from the radiator to both heater cores, water pump, freeze plugs, etc. Seems these have a history of the coolant system components going south. I had the same problem where it turned out to be the either front or rear heater cores. OR a very small leak in the system that the smell was coming in the fresh air vent.
One case, the intake gasket had a very small leak. Typically after running the vehicle good and warmed up, I'd shut it off and listen for any escaping steam or such.
SPONSORED LINKS
Wednesday, January 16th, 2008 AT 12:01 AM
