1995 Ford Aerostar Overheating
LOISJE
1995 Ford Aerostar All Wheel Drive Van
110,000 and I think it is a 4.6 engine.
Was advised I had a head gasket leak by one mechanic. Another told me the heads were fine & that I had a cracked block. Still another told me that a cracked block is rare for an Aerostar because the blocks are cast iron. What's your thoughts? I am debating on just having the shaved heads put back on the engine. Is there any way to know whether or not I have a cracked block?
Thank you very much.
Lois
Jul 8, 2007 at 2:34 PM
2CARPRO JACK
  • 11,533 POSTS
The odds of the block cracking are pretty slim. Have done a ton of heads/head gaskets on those vans.Be sure to have them pressure tested as well as surfaced when off the vehicle
Jul 9, 2007 at 1:09 AM
Suggested Repair
Have the cylinder heads pressure tested and surfaced while they are off the vehicle before reinstalling them. A cracked block is unlikely; head gasket or head work is the more common repair on these vans.
Conversation Summary
The owner of a 1995 Ford Aerostar with overheating received conflicting diagnoses of a head gasket leak versus a cracked block and asked whether the block could be checked before reinstalling shaved heads. The expert said a cracked block is unlikely and recommended pressure testing and surfacing the heads while they are off the vehicle.
