1992 Ford Aerostar Only One Gear Works
1992 FORD AEROSTAR
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
MYBRAINMAN
  • 17 POSTS
I have a 1992 Fors Aerostar with a 4.0 motor. I have a problem with the trans mission. All gears except for hill gear 2 dont work. Drive, Over Drive, Revese, and hill gear 1 will not work and there is a low gringing sound when put in gear, but in hill Gear 2 I can drive any were I need to but need to know what is wrong with the other.
Nov 17, 2008 at 10:36 AM
  • 31,937 POSTS
Hi there ,
The noise is a concern, i feel that there has been a mechanical failure with in the transmission drive train, i would suggest that you get a transmission specialist to inspect and report for you, the more you drive it the more damage i feel that you will be doing.
mark (mhpautos)
Nov 17, 2008 at 8:18 PM
