TRANSMISSION RANDOMLEY DOWN SHIFTS OUT OF OVERDRIVE
1994 FORD AEROSTAR
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARKYATES
I have a 1994 Ford Aerostar. When driving on the freeway at 65mph +/- in overdrive...
The transmission will randomly downshift into drive and stay in that gear...
Sometimes, (after a few minuets) it will then randomly up shift back into OD, but this is rare...
When it downshifts out of OD, nothing I do (use the column to shift into other gears and back, into neutral and back) will make it up shift back into OD when I return to that gear...
Now here is the only thing that works...
When the transmission (randomly) down shifts into drive, I can get it to up shift back into OD, by stepping down on the accelerator, but as soon as I let off slightly, it downshifts again immediately...
To me it feels like it is a vacuum signal issue but I don't know anything about this vehicle/trans characteristics
Feb 11, 2014 at 11:40 PM
HMAC300
  • 48,601 POSTS
have a trans guy look at it your o/d is probably bad
Feb 12, 2014 at 12:05 AM
  • 110,240 POSTS
Has the check engine light or OD light come on? Is the trans fluid clean and full?
MARKYATES
The trans was rebuilt by one shop, and the problem continued...
a year later I had it rebuilt by a more competent shop... the problem continues...
Feb 12, 2014 at 1:30 AM
MARKYATES
no, no, yes and yes..
Feb 12, 2014 at 1:32 AM
HMAC300
  • 48,601 POSTS
if it is still continuing then take it back they shold warranty it if it is still doing the same thing.
Feb 12, 2014 at 1:55 AM
