I need the firing order for a six cylinder 2.3 liter engine for the truck listed above.
Saturday, October 17th, 2020 AT 6:45 AM
MECHANIC
Please see the attachment for the firing order information for the 2.3L. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Let us know if you need more info. Thanks
Images (Click to make bigger)
Saturday, November 14th, 2020 AT 4:59 PM
SPITEFIRE
MEMBER
1 POST
1991 FORD RANGER
I need the firing order for my six cylinder Ranger with a distributor.
Wednesday, June 9th, 2021 AT 1:59 PM
(Merged)
MECHANIC
Here is a diagram of the firing order for your truck.
Let us know if you need anything else.
Image (Click to make bigger)
(Merged)
NICK LUCERO
MEMBER
1989 FORD RANGER
2.3L
4WD
MANUAL
29,678 MILES
Need diagram for firing order.
(Merged)
MECHANIC
Please see attached. Let us know if you need more info. Thanks
Wednesday, June 9th, 2021 AT 2:00 PM
(Merged)
NICK LUCERO
MEMBER
It's got 8 plugs.
(Merged)
MECHANIC
Correct. But this is a 2.3L correct? If it is then you have what is called a waste spark plug. I included a picture of both sides of the engine. You have a coil pack on both sides that has the same firing order of 1-3-4-2.
Take a look at all this info and let me know if you have questions. Thanks
(Merged)
TKSTOWERS
MEMBER
1988 FORD RANGER
4 CYL
2WD
MANUAL
99,000 MILES
How do I line up the marks both dots up or facing each other or what? Which way does the firing order on the dist cap go counter clock or clock
(Merged)
MECHANIC
See below
(Merged)
TKSTOWERS
MEMBER
Thanks that helps would you have an illustration for the timing marks? This would be helpful
(Merged)
MECHANIC
Are you talking about the sprockets alignment? If so see below
I know the firing order on block cant find firing order on distributor
(Merged)
BMRFIXIT
MECHANIC
Good luck.
(Merged)
WESDURYEE
MEMBER
1 POST
1987 FORD RANGER
I put new distributor and wires in and and lost track of which were went where. Want a picture of firing order
(Merged)
JDL
MECHANIC
I have seen pictures that were not accurate.
(Merged)
PACHYAUTO63
MEMBER
1986 FORD RANGER
2.9L
6 CYL
4WD
AUTOMATIC
125,000 MILES
Can you show me the firing order?
(Merged)
JDL
MECHANIC
This is for 2.9L engine. Hope it helps.
(Merged)
COLETURNER08
MEMBER
1986 FORD RANGER
I have a 1986 Ford Ranger with a 2.3l. The block is a 1989 and the rest is a 1986. I got spark and gas. The timing is set to specks with cam and crank but it don't want to start. Could it be the computer or the cylinders.
Could the cylinders be reversed?
(Merged)
MERLIN2021
MECHANIC
Order is 1-3-4-2 for BOTH coil packs
(Merged)
MERLIN2021
MECHANIC
Cams are different on 86 and 89, what cam is in it?
