1996 Fiat Bravo windscreen cleaner...
1996 FIAT BRAVO
130,115 MILES • 4 CYL • FWD • MANUAL
TP85Z
Hello.. I have a problem with the windscreen cleaner..when i try to activate it i can hear it pumping the water from the tank but the water is not reaching the windscreen..i check the nozzsles but the seem fine..What else can I do?? please write soon thank you
Sep 15, 2010 at 9:54 PM
Check if its clogged-up between the pump/tank and the nozzles
Sep 15, 2010 at 10:08 PM
TP85Z
Thank you for helping me..!!I checked more carefull ..well the rubber tube was not clugged-up but cut in two points..!! I shall replace it..thank you again!!
Sep 15, 2010 at 10:59 PM
