Fan won't engage, vehicle overheats when not on highway
1998 LINCOLN MARK VIII
210,000 MILES
STEVEPOONS
  • 12 POSTS
I started having an issue with my 98 Lincoln Mark VII where the car would overheat whenever I am not on the highway and am just traveling in city streets. It seems that the radiator fan is not turning on. What would be my first steps for diagnosis. I'm assuming it's most likely a relay or connection issue, but I am unfamiliar with the location of the fan relay.
Thanks
Sep 23, 2013 at 10:22 AM
WRENCHTECH
  • CAR REPAIR CONTRIBUTOR
  • 20,761 POSTS
Don't be so quick to assume things.
The fan is operated by an electronic module called a Variable load control module and may require some high tech equipment to diagnose.
Sep 23, 2013 at 12:14 PM
