Extended cranking between cold and hot
28,600 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
CELLOBIKER
Car starts perfectly when cold or hot, but in between it requires two to three tries. The engine then sputters to life, sounding like it is not getting enough fuel.
Once it gets going it runs fine. No engine lights. I already replaced the air filter and the fuel pressure sensor.
Feb 17, 2017 at 4:57 PM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge auto parts rent it. it may be low on pressure causing this. See link.
Feb 17, 2017 at 10:06 PM
CELLOBIKER
Thanks so much. Car is going in the shop. Will keep you posted!
Feb 18, 2017 at 3:43 AM
CELLOBIKER
You were right! Low fuel pressure caused by a bad fuel pump. Got a Delphi and the car starts perfectly - at all times. Many thanks!
Feb 21, 2017 at 4:09 AM
  • 55,588 POSTS
Yep HMAC300 is one of our best!
Glad you could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Feb 23, 2017 at 7:35 AM
