Excessive fuel consumption
2012 TOYOTA COROLLA
55,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
OBIAJULU ONYEKA
I have a gulf edition, it takes so much fuel and sometimes the acceleration is stalled. it shows no light on the dash at all. I have serviced the nozzle, changed the plugs still the problem persisted. I took the car for a diagnosis and it showed only one error which is stability malfunction. I was told the plugs I bought was not original and that I should change them. some other person said I am using the wrong fuel for the car (I use Mobil 1). Please what do you suggest I do? if it is the plugs, so you have original plugs that I can buy and be sure that the issues will stop? Imagine travelling 300 km and the fuel finished entirely.
Please I need your advice. Thanks
Dec 13, 2016 at 1:42 PM
HMAC300
  • 48,601 POSTS
put correct plugs in car then check fuel pressure with a gauge and look for a vacuum leak like a hose off etc. See link.
Dec 14, 2016 at 4:08 AM
