Excessive exhaust steam
2011 MAZDA 3
130,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
JMF2017
  • 5 POSTS
My car is in the shop and they are having trouble confirming head gasket issue. I am experiencing excessive white exhaust steam. Both at startup and driving for over twenty minutes. Also sputtering cold starts. The shop observed the smoke and ran a compression test and the chemical gas test testing the overflow reservoir gases. Both are normal. Also, no coolant loss observed. Can it still be a head gasket issue? Can it be a fuel injector? The shop has been around over thirty five years. Are there other tests to be run? They do not want to remove the cylinder head on a guess. Please advise. Thanks!
Dec 26, 2017 at 7:01 AM
CARADIODOC
  • 34,367 POSTS
White smoke from the exhaust is indeed a sign of burning coolant, but it is hard to believe there has been no loss of coolant. To verify if it really is coolant that is being burned, consider adding a small bottle of dark purple dye to the coolant, then search a day or two later with a black light. The dye will show up as a bright yellow stain. If you find the dye inside the tail pipe, it has to be coolant.
Dec 26, 2017 at 7:14 AM
JMF2017
  • 5 POSTS
Thanks for the help! What type of dye should be used? Quantity to be used?
Should I mention to the auto shop? Is this a common procedure used in auto shops for analysis?
Dec 26, 2017 at 7:27 AM
CARADIODOC
  • 34,367 POSTS
Very common. Auto parts stores have the dye in tiny bottles. They will ask what fluid you are testing and will give you the right dye. I just use half a bottle, and save the rest for the next job. Most shops already have a black light, but if not, you may find one at an auto parts store that rents or borrows tools.
Dec 26, 2017 at 7:42 AM
