evaporator cleaning
1995 CHEVROLET BERETTA
38,000 MILES • 6 CYL
KMKK1010
hello everyone! first I want to thank you for your help and assistance in getting my new air conditioner compressor installed. so far it has been a smashing success and works very nicely. however in order to maximize my cooling efficiency and operation I would like to gain access to at least part of the evaporator, just enough to be able to get some evaporator cleaning spray in there. being that the evaporator has never seen the light of day and there is no cabin filter I believe over the past twenty years it has become quite gunked up. If somebody has some pointers as to how to get some spray in there or otherwise clean the evaporator through some kind of access point, I would really appreciate it. Thanks!
Aug 18, 2016 at 5:50 PM
CARADIODOC
  • 34,366 POSTS
The majority of the comfort does not come from cooling the air. It comes from removing the humidity. That's why air conditioner compressors run in winter when we select the "defrost" mode. It removes the humidity so it does not condense on the cold windshield.
That condensation is the water you see running out of the drain tube and onto the ground just left of and behind the right front tire when the system is running in the summer. That water on the evaporator traps pollen and dust, and those get washed off as the water runs out. When you pull a heater box apart, the only time you will find built up dust is when the system hasn't been working for years.
The only spray you will find at dealerships for air conditioner systems is an odor neutralizer, and that is only used when mold has formed in the heater box due to that condensate not draining freely. The product is sprayed into the vents from inside the vehicle and into the air intake under the hood or in front of the windshield. When spraying into the air intake, run the fan on the lowest speed to draw the spray in.
Aug 18, 2016 at 6:03 PM
KMKK1010
Thanks for the quick response. I have heard everything you had to say. actually the air conditioner system has not worked for about five years. I received the car with just a bypass pulley in place of the compressor. so there has been no rinsing action taking place on the evaporator. Therefore ,I must assume that there must be a buildup of some kind, however little it may be ,I would like to get rid of it just so I know I have a completely clean system working as good as it possibly can. do you know what the easiest way is to gain access to the evaporator? can I get in there by removing the blower motor? thanks for any assistance you can give.
Aug 18, 2016 at 11:39 PM
HMAC300
  • 48,601 POSTS
Evaporators have very little buildup of anything even after twenty to thirty years.
Aug 19, 2016 at 12:54 AM
CARADIODOC
  • 34,366 POSTS
Yup. I agree.
I've never tried getting to an evaporator by removing the bower motor. I doubt it would be that easy. Normally you have to discharge the refrigerant, disconnect the heater hoses and AC lines, then remove the dash board to remove the heater box. Once removed, the heater box has to be disassembled to get to the heater core and evaporator. It's a really big job that most professionals run away from.
You're trying to do something that none of us has ever attempted or heard of anyone worrying about, My fear is you're going to cause a lot more trouble than anything you think you're going to fix. Taking dash boards apart has a way of resulting in elusive squeaks and rattles, and often things that don't work resulting in having to take everything apart again. If you're really determined to find dust to clean, take the side trim panels off and look behind them. Watch out for sharp metal points and screw tips so you don't cut yourself. If you wipe a rag around in those areas, you'll be amazed at what you find in even the cleanest of cars.
Aug 19, 2016 at 1:14 PM
