Error code P0499
176,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
MIKE MCCALLIE
Local service technician stated "current code: leak detection pump canister vent valve solenoid high. No TSB's or recalls. Concerning current codes. Have power and ground to leak detection pump (LDP). Found LDP testing bad. Recommended starting with new LDP but may still have PCM problem. Replaced LDP and cleared codes. Code came right back. Suspect PCM problem. Recommend dealer to check PCM." I know taking it to dealer will cost a fortune. So, is there a way to reset the PCM to fix the problem? If not, I assume that I could purchase and install new PCM and that would fix the problem? Thanks.
Jun 19, 2017 at 11:58 AM
CARADIODOC
  • 34,398 POSTS
I cannot tell if you are stating what the mechanic wrote on the repair order or if that is what you did. The problem is diagnostic fault codes never say to replace parts or that one is bad. They only indicate the circuit that needs further diagnosis. In this case the code is caused by a break in the circuit, and that is most often due to a corroded connector terminal. Next would be a cut wire or a bad pump motor. The last thing on that list would be the engine computer. It tried to run the pump but detected the open circuit.
Jun 19, 2017 at 2:15 PM
MIKE MCCALLIE
Thanks. The reply was from the service technician. As for the corroded connector terminal are you referring to the four connectors at the PCM? If so, they are fine. The battery cables are fine as well. Also, the technician replaced the leak detection pump so that should not be the problem. That leaves me with the PCM, right? Can it be reset by me or can I replace the PCM?
Jun 20, 2017 at 12:57 AM
CARADIODOC
  • 34,398 POSTS
I wasn't clear in my explanation. The computer can detect hundreds of defects, and the fault codes get very specific as to which circuit has the problem. Don't worry about the battery cables and things like that. This code refers to the wires related to the leak detection assembly, and that assembly. Specifically, terminal number 8 at the Engine Computer is a white / dark green wire going to the leak detection assembly. That wire can have a break or cut in it, but a corroded or stretched connector terminal is a better suspect. The leak detection assembly also has a ground wire that competes the circuit that has the problem, therefore, that black wire also needs to be checked for breaks or a corroded terminal where it bolts to the body. This ground is listed as being near the battery. That is a good place to find a corroded connection from acid leaking from a battery that's about to fail.
The Engine Computer is part of this circuit too, but they cause very little trouble. Even the terminals in that connector are very reliable, so those should be the last suspects after everything else is ruled out.
Jun 20, 2017 at 2:51 PM
