2004 Dodge Dakota engine codes
2004 DODGE DAKOTA
QUINN HIX
Computer problem
2004 Dodge Dakota 6 cyl Two Wheel Drive Automatic
what does the code p0499 mean
Jun 18, 2010 at 4:25 PM
  • 110,244 POSTS
It is most likely a bad vent valve solenoid. Check the wiring connection and wiring closely to make sure a wire is not unhooked or broken, but it is most likely the switch itself. It should be very close to the evap canister.
Jun 19, 2010 at 4:33 PM
