2015 Ford Taurus Vents Won't Change
94,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
OZ1991
  • 14 POSTS
My A/C is working fine except for the fact that I cannot seem to be able to deviate the flow of air from the dashboard vents to any other direction (outlet).
The local mechanic had suspected the left (driver side) door actuator part going bad when the above shown error codes come up, which I've replaced and still to no avail.
Is there a way to figure out which part has gone bad instead of having to replace all 4 pieces?
Jan 14, 2024 at 5:12 PM
  • 55,766 POSTS
Code B1086:07 is for one of the blend door actuators and the 07 part is for a problem such as a short circuit or open circuit. The fact that you can't change the vents is telling us it is the mode actuator. It looks like it is on the driver's side so you will need to remove the panel under the steering column. This can also help you recalibrate the system. Check out the images (below). Let us know what you find.
Jan 15, 2024 at 1:09 AM
Suggested Repair
The inability to change vent direction points to the mode door actuator, not just a blend door. Access the driver's-side actuator by removing the panel under the steering column, check for a short or open circuit indicated by code B1086:07, and recalibrate the HVAC system.
Conversation Summary
A 2015 Ford Taurus owner can cool the cabin but cannot redirect air away from the dashboard vents. Codes B1086:07 and 13 were present; replacing the suspected driver's-side door actuator did not fix it. The expert said B1086:07 indicates a blend door actuator circuit fault such as a short or open, while the stuck airflow points to the mode actuator on the driver's side. They advised removing the panel under the steering column to inspect it and recalibrate the system.
