Engine will not stay started
190,000 MILES • 4.2L • 2WD • AUTOMATIC
QUINCYF93
The only way it will fire up is if I build the fuel pressure by turning the key 4 or 5 times. Then it will fire up then turn off within 40 seconds. When I try to hit the gas pedal it just makes the engine shut off. I changed the fuel pump and cleaned my throttle body.
Jul 28, 2019 at 4:26 AM
  • 55,732 POSTS
This sounds like you have a throttle pedal position sensor or throttle actuator that is not working correctly. To be sure lets run the codes to see what we find. here is a guide:
Jul 29, 2019 at 4:40 AM
QUINCYF93
Unfortunately none of the codes are popping up because I got a new battery. But I already replaced the TPS unit.
Jul 29, 2019 at 8:47 AM
  • 55,732 POSTS
The codes will still be there even with a new battery because they stay in the computer memory until cleared. But it could be a clogged catalytic converter that is causing the issues as well here is a guide to help. Please run the codes
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Jul 30, 2019 at 3:49 AM
QUINCYF93
I ran the codes & nothing popped up. They where cleared.i got a new catalytic converter put on a month before this started happening
Jul 30, 2019 at 4:19 AM
  • 55,732 POSTS
You could have a bad gas. when you had the tank out did you use a flashlight to look for water in the fuel? Also, can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jul 31, 2019 at 2:54 AM
