Engine will not turn off with key - Accesories (power windows, etc. have power with key removed)
2003 KIA SORENTO
120,000 MILES
JOJONKENNE
The question comes in two parts:
1. My engine will not turn off when the key is turned off. I replaced the ignition switch as I thought that would be the obvious choice but that didn't fix the problem. Help!!
2. Also all of the instrument cluster lights (chk engine, brake, park, oil, etc.) stay on when the key is removed. The only way that I can get them to go out (so my batt. doesn't drain) is to disconnect the batt. Help!!
I thought that the new ignition switch would fix my problem but it didn't . It appears that there was nothing wrong with my old one as I can disconnect the harness to the switch and nothing changes.
Thanks for your time.
May 14, 2013 at 11:43 AM
are there any aftermarket accessories on the car??
May 14, 2013 at 12:00 PM
JOJONKENNE
I did have an after market alarm system but I removed it a few years ago. The harness is still tied in but it is not hooked to anything.
May 14, 2013 at 12:31 PM
