Engine will not start
200,000 MILES • 3.9L • V6 • 4WD • MANUAL
EDWINA F DAWSON
  • 32 POSTS
Replaced water pump and it was running fine until the clutch gave out. Replaced clutch plate, throughout bearing, fly wheel and crankshaft position sensor. Engine will not turn/start.
May 26, 2018 at 8:44 AM
CARADIODOC
  • 34,414 POSTS
Please be sure I am reading this right. You have a no crank condition, meaning the starter does not spin the engine. Why did you replace the crankshaft position sensor? That implies the starter is working okay but the engine will not run.
If this is a no crank problem, do you hear a light click from the starter relay when you turn the ignition switch to "crank"? Do you hear a single, rather loud clunk from the starter? If you do not hear anything, what happens to the brightness of the head lights or interior lights when you try to crank the engine?
May 26, 2018 at 12:30 PM
EDWINA F DAWSON
  • 32 POSTS
Engine cranks like it is suppose to do. Lights work normal . No weird noises. Just no spark or fuel pump hum.
May 27, 2018 at 7:25 AM
EDWINA F DAWSON
  • 32 POSTS
The crankshaft bracket fell apart and could not be repaired, i.e. , new CSS. Was informed that if we do this we need a new flywheel, as well. New CSS has a "L" shaped bracket not like the original which fell apart when we "dropped" the transmission. We still have the old parts.
May 27, 2018 at 8:19 AM
CARADIODOC
  • 34,414 POSTS
So the engine does turn, hence my confusion. It sounds like you are describing a simple case of forgetting to remove the crankshaft position sensor before working on the clutch. I am not sure why replacing the flywheel is necessary. There are differences in the numbers and locations of the notches in the ring around it that are detected by the sensor. Those pertain to different years and engine sizes which is why some people run into unexpected problems when they change their engines and use one from a different year. As long as you keep the original flywheel/torque converter, there will not be a problem.
It sounds like you are looking at a crankshaft position sensor for a different engine. Here is a photo of what yours looks like. I looked at applications two years older and two years newer, and other engine sizes, all for Dakotas, and there is no other sensor style shown. I have seen what you described with just one mounting hole, but those were typically found on front-wheel-drive cars and minivans.
May 27, 2018 at 12:43 PM
EDWINA F DAWSON
  • 32 POSTS
The old sensor bracket was made of solid material (some type of metal) it had two holes for mounting.. We double checked OEM's Dodge dealer picture is what we were given. We attempted to use old flywheel and were told no must get new one. Dodge Dealer. Manual shop/Chrysler does not mention removal of sensor first but that is a logical step. When removed the metal crumbled. Went to "junk" parts and found same type of sensors and they were made the same as mine and they were crumbling, as well. New fly wheel notches are the same , however, there are marking lines midway from the center to edges of same. Dodge has not been helpful in this situation, either. All parts numbers were verified by Dodge The only difference with the photo of sensor is the color of the metal bracket. They have two mounting holes and they line up with old mounting plate. Plate on body of truck dates it manufactured 03/1996 and I have a 3.9L engine.
According to parts department at the local Dodge dealer all parts numbers are correct. Mechanic working on vehicle is upset because all procedures were followed as prescribed and now I am without a vehicle. This truck has had only one owner and after 200,000 miles it finally gave up the clutch. Never had any problems with the standard shifting mechanism. It is a five speed and ran great. How do we resolve this ? Your information seems to be different than what we discovered. The shop manual does not show the new sensor configuration but the old (block type).
May 27, 2018 at 1:45 PM
CARADIODOC
  • 34,414 POSTS
I am just going by the information from my research, and from memory. Is there a reason you need to replace the flywheel?
May 27, 2018 at 1:54 PM
EDWINA F DAWSON
  • 32 POSTS
We were told the old one would not match with the new sensor. We already tried it with the old flywheel and had the same problem.
May 27, 2018 at 2:03 PM
EDWINA F DAWSON
  • 32 POSTS
Is there any possibility that the sensor was some how changed?
EDWINA F DAWSON
  • 32 POSTS
My Dodge is a bit different, not a 20 gallon tank, but almost 22 gallons and oil changes take a bit more than five quarts. I have had the same mechanic for thirteen years until he retired and now have a new one.
May 27, 2018 at 2:07 PM
CARADIODOC
  • 34,414 POSTS
Those are not really relevant to our story. My minivan has an 18 gallon gas tank, and I can get 20 gallons in it without having to shake the van to settle the gas.
I am not aware of any changes. What was the problem? Was it just a crank no start or was the sensor being hit and broken by the ring on the flywheel?
May 27, 2018 at 3:57 PM
EDWINA F DAWSON
  • 32 POSTS
I mentioned the quantity as it was a surprise to me when I purchased the truck that is was a 22 gallon and not just 20. The sensor had to be removed from the fly wheel to drop the transmission and replace the clutch plate and through out bearing. When removed the bracket began to fall apart crumbling to the extent that there was nothing left so it could be used again. Every sensor found at the used parts yard. was in the same crumbling condition. Solution was for Dodge to redesign sensor bracket. I was told I would have to purchase a new sensor. Work was done, old flywheel put in place, new sensor in place and engine no start Dodge Dealer said I would have to replace the flywheel to match the new sensor . New flywheel installed and everything back in place and still no start. Engine cranks like it is supposed to. Lights work normal. No weird noises. Just no spark or fuel pump hum. This is the problem, simple, but not. Mechanic is perplexed and I am not amused at this point. I need my truck and cannot afford a new vehicle. At 76 that is not a solution. There must be something overlooked. How can we remedy the problem?
May 27, 2018 at 4:49 PM
CARADIODOC
  • 34,414 POSTS
I cannot argue against what you were told, but I find it hard to believe Chrysler would come up with a new sensor design and expect everyone to buy a new flywheel. That goes against Chrysler's corporate culture since the 1930's where they put customers' best interest ahead of profits. According to a group of national-level instructors, they still have the highest "customer-friendly business practices", after Hyundai and Toyota. We will not discuss the bigger manufacturers that are at the bottom of that list.
As a point of interest, Chrysler only makes about twenty percent of their own parts, not including sensors. Those are contracted out to independent suppliers. Chrysler tells them the specifications the part must meet. It is real common to go to the dealer's parts department and find the part you need has been "superseded" by a new part number. We have no way of knowing what changes they made for reliability or to address a common problem, but the new part number is supposed to replace the old part, rarely with any modifications. The only exception I can think of is the camshaft position sensor on some four-cylinder engines. They had a sensor for a different application already in production, and it was a better replacement for the problem-causing sensor, except the plug was a little different. From then on, that sensor came with a new plug to splice into the harness, if necessary.
Given all of your story up to this point, it is safe to assume the no-start is related to only the crankshaft position sensor. The way I would approach this now is to connect a scanner to view the signals from that sensor and the camshaft position sensor. I have a Chrysler DRB3 scanner for all of my vehicles. With an extra plug-in card, those were able to do emissions-related stuff on all brands of cars and light trucks sold in the U.S. starting with 1996 models, so a lot of independent repair shops bought them. By 2004 they started to become obsolete, and the last model year they worked on was the 2008 Jeeps. Because of that, the shops had to buy something else to work on the newer models, and those newer scanners also usually work on the older vehicles. That means the DRB3's do not get used much anymore, and you can find them on eBay. In fact, since the dealer I used to work for still likes me, they sold me four of those scanners years ago. I sold three on eBay to pay for the one I kept.
To address the needs of my newer truck, I just bought a Snapon Solus Edge, also from eBay, but here is where you might be able to score a good deal. Snapon charges shops $1,000.00 per year to upgrade the software to the latest version, but here is one of those "customer-unfriendly business practices". If that scanner is only updated to 2014 models, you are required to buy the 2015 update, (for $1,000.00), before you can buy the 2016 update, (for another $1,000.00), so you can buy the 2017 update. This scanner only costs $3,900.00 new with the latest 2018 updates, so it's silly to try to upgrade the older scanners. For this reason, you will find a lot of them on eBay for less than $900.00, and they are good for up to 2012, and maybe 2014 models. If it covers all the year vehicles you want to use it on, you do not ever have to buy any updates. Just use it as is. This way they do not have any value to repair shops and you will find them to be very inexpensive. If you are going to be working on your own vehicles in the future, you will be amazed to see what you can do with a scanner that you never knew you could do.
To color the story a little, I am chasing an elusive problem on my 1994 Grand Voyager, and since I have my DRB3 borrowed out to a friend, I wanted to use the new Solus Edge, but for 1995 and older vehicles, it requires a different cable, and a Chrysler connector adapter which I do not have. I am suspecting I have a failing crankshaft position sensor, and I want to view the signal status on a scanner, but so far I do not know how that would be displayed on the newer scanner. If you can find a shop with a DRB3, the two sensors are on a long list of "Inputs/Outputs", and they are shown as "Present" or "No", during cranking and/or running. This will tell you instantly if a signal is showing up from the crankshaft position sensor. Be aware you could have absolutely nothing wrong with your crankshaft position sensor or its signal. There are other things that can cause the symptoms you have. Without a scanner, you have no way of knowing what is missing.
For the next part of my wondrous story, be aware the air gap for that sensor is critical. The older design was adjustable by means of a thick paper spacer glued to the end of it. You were to push the sensor in as far as it would go, at which point it was hitting the ring on the flywheel or torque converter. As soon as you cranked the engine for the next time, that spacer slid off and was discarded, but at that point its job was done. If you ever needed to remove that sensor and reinstall it, you were to stick a new spacer on the end. A lot of aftermarket replacement sensors had a thin plastic rib molded to the end to set that air gap. Once the engine was running, that rib would typically wear down a little, so when that style needed to be removed and reinstalled, you were supposed to cut the rib off, then stick on the paper spacer.
With your sensor design, no adjustment, (no misadjustment), is possible, which leads me to believe that air gap is not quite as critical.
Assuming there is no signal showing up from the crankshaft position sensor, here is a list of things I can think of that could cause the problem: First would be a wiring problem. With the ignition switch on, one of the three wires must have a supply voltage coming from the engine computer. Typically that is 5.0 volts, but it could be 8.0 volts, 10 volts, or even possibly 12.0 volts. That voltage will not be there and be wrong, so the exact voltage you find is not what is in question. The question is, do you have it or do you not? If it is there, check the ground wire next. That is shared with other sensors and that wire goes to ground through the engine computer so it can be monitored. For that reason, you will find it is at 0.2 volts. If you have both of those, the third wire is for the signal, and when that is developed varies depending on the design of the sensor. Most of these are magnetic, and they detect interruptions in their magnetic fields created as a hole in the ring on the flywheel moves past the sensor's magnet. When these have internal circuitry in them to amplify those tiny electrical pulses, you can often see the signal voltage change from something real low to something close to the supply voltage when you slowly rotate the crankshaft by hand. This is the signal the computer is looking for when it changes to "Present" while cranking.
Some of these sensors develop their signal voltage simply by their magnetic field being disturbed, but there is no amplifying circuitry inside them. Those almost always use only two wires. One of the critical variables with this design is speed. The faster the ring with its notches moves past the magnet, the higher the signal voltage will be developed. That voltage has to reach a certain value before the computer can read it. You will never be able to rotate the crankshaft fast enough by hand. In fact, many of these do not even develop a useful signal until the engine has started running on some other sensor(s) first.
The next variable is that air gap. If that is wrong, I suspect you would see an erratic "Present" or "No" on the scanner during cranking. Since we are dealing with some unknowns here, I would entertain a notion to learn more about the air gap you have. First pull the sensor out and be sure it did not get broken from hitting the tone ring. If that did happen, that has to be the wrong sensor for that application. Next I would stick a little grease on the end, about 1/8" thick, and a piece of paper over it so the grease does not stick to the tone ring. Push the sensor in all the way, then pull it out and look at how much that grease compressed. The air gap on the older sensor design was about 1/16". I would expect to see the same thing on yours. If you have to repeat this with a thicker glob of grease, the air gap is too big and the sensor cannot be expected to generate a usable signal. Look for excessive rust or dirt buildup on the flywheel housing that is holding the mounting bracket up too far.
The next thing that makes me nervous is the new flywheel. Chrysler has always been famous for real good parts interchangeability, but when it comes to these flywheels, while they all bolt on the same, it is those notches that have to be right. I am not aware of any publication that lists what is needed for each year and engine size. I only know to replace it with one that has identical notches. For V-6 engines, there will be three groups of notches. Typically there will be four notches in each group. With this design, the computer only know when a cylinder is coming up on top dead center. It needs the signal from the camshaft position sensor to know which piston is coming up on its compression stroke, and it relies on the distributor to send the spark voltage to the correct cylinder.
On some V-6 engines, two groups of notches still have four notches in each group, but the third one has only three notches. With this design, the computer can tell by counting the signal pulses, which pair of pistons is coming up on top dead center. These engines usually use a single ignition coil to fire those two cylinders at the same time, and there is no distributor. One cylinder fires on the compression stroke, and the mating cylinder fires on the exhaust stroke. That is referred to as "waste spark". This is where you can get the wrong flywheel/flex plate with the wrong groups of notches. When the computer is programmed to count four pulses, four pulses, and four pulses, per crankshaft revolution, if it sees four, four, then three pulses, it gets confused and will wait for that last fourth pulse. Basically, the computer has to be matched to the tone ring. This is where when people swap in an engine from a different year, and they keep the flex plate from the replacement engine, it is wrong and they have a crank/no-start.
I just realized I am using the terms "flex plate", "flywheel", "torque converter", and "tone ring" to say the same thing. I am sorry if that has led to any confusion. What I am referring to is that metal ring with the square holes in it.
One thing I would like you to set my mind at ease is to listen if you can hear the hum of the fuel pump for one second when you turn on the ignition switch. If you cannot tell, take a test light and back-probe the wire at one of the fuel injectors. Typically that will be a dark green/orange wire. It is the wire that is the same color at every injector. You should see the test light turn on for one second. If you do not, we have some other problem to diagnose. If it does, just out of curiosity, see if it turns back on during cranking. Here again, if it does, there is some other problem. The computer turns on this entire circuit when it sees signal pulses from the crankshaft position sensor and the camshaft position sensor.
May 28, 2018 at 11:44 AM
EDWINA F DAWSON
  • 32 POSTS
Now we are getting somewhere. Will let you know what happens ASAP.
May 28, 2018 at 12:04 PM
EDWINA F DAWSON
  • 32 POSTS
Thanks.
May 28, 2018 at 12:08 PM
  • 55,721 POSTS
Please do CARADIODOC is one of our best!
May 31, 2018 at 5:34 AM
EDWINA F DAWSON
  • 32 POSTS
Still no. The mechanic working on my vehicle read your response and sent a reply. Not sure if you got it. This is critical for me and being a certified mechanic with his own shop I dare say embarrassing. If you received his message under my name (here) be advise it is legit. If no message was received , again, please advise.
May 31, 2018 at 5:43 AM
STEVE W.
  • 15,413 POSTS
Looking at the part numbers and the pictures I see they show one sensor part number #56027273 for manual transmissions and a different part number #56027272 for automatics. They look identical in the pictures except for a small connector alignment tab inside the shell. Might be grasping at straws but it may be that it is the automatic sensor and not the manual? I would not think the connectors would go together but have seen stranger things happen.
May 31, 2018 at 7:16 AM
EDWINA F DAWSON
  • 32 POSTS
Checking for that information.
May 31, 2018 at 12:28 PM
STEVE W.
  • 15,413 POSTS
Have you had any luck getting your vehicle running?
Jun 4, 2018 at 12:57 AM
EDWINA F DAWSON
  • 32 POSTS
No. This is what was done: Continuities tests on wires I could get to both sides all okay. Checked part number for sensor correct. I used a jumper wire to the coil, distributor and voltage test on the coil, distributor and fuel injectors. None were receiving voltage even when I used the jumper I could not get a spark. No hum of the fuel pump and never heart it on initial key on one to two seconds bursts or during cranking. Replaced the add relay with a known good relay and the fuel pump with a known good relay. No dice there either.
Jun 4, 2018 at 9:02 AM
STEVE W.
  • 15,413 POSTS
Does this truck have a tachometer? Is it registering anything during cranking? It ran fine up until changing out the clutch, where Dodge had you switch the flywheel and CKP sensor, correct? Do you have access to an O-scope? If yes connect it so you can see the signal from the crank sensor. Chrysler likes to change things at times, I am wondering if the "new" flywheel might have the wrong trigger sequence. They did that a few times over the years. You may be able to see the notches if you pull the crank sensor and use a bore scope. Count them and compare it to the old unit. A bad crank signal shuts down most of the engine controls to avoid damage.
Jun 4, 2018 at 11:00 PM
EDWINA F DAWSON
  • 32 POSTS
According to the mechanic, we put in the new sensor with the old flywheel and no start. Was told we may need a new flywheel and still and still no start. I have seen both flywheels, notches in same place but of face of flywheel midway on radius shiny band looks like a CD. I will forward your information to Mr. Compo, the mechanic and will let you know his results. E
Jun 5, 2018 at 2:55 AM
EDWINA F DAWSON
  • 32 POSTS
Steve, the problem started after we put in the new sensor. The old sensor crumbled fell to pieces and had to be replaced. New sensor , old flywheel and no start. Dodge recommended new flywheel. According to Mr. Compo everything matches the old flywheel. Sent your message to him and am waiting for his response. I can understand a "shut off" switch but there must be a reset? To disengage that action?
Jun 5, 2018 at 3:16 AM
STEVE W.
  • 15,413 POSTS
He installed the new sensor and it stopped running. Did he try a second sensor? Would not be the first time a part was bad out of the box. Especially with the parts "quality" these days. That is a three wire sensor, it has a power feed to it, a ground and the signal. It is not uncommon for them to lose one of the circuits. You wrote that the circuit was tested and was K, was that just at the sensor connector or at the connection on the PCM itself? The sensor may be fine but the harness may have a bad connection.
Jun 5, 2018 at 7:59 AM
EDWINA F DAWSON
  • 32 POSTS
Hmm. I thought of that too, but I have not heard from Mr. Compo today. He did mention that he tried more than one sensor as the first replacement was not correct. Something about the bracket for it interfered with the flywheel, but only he can give you the exact account. Hopefully he will stop by here on his way home with some information and forward a message to you.
Jun 5, 2018 at 8:50 AM
EDWINA F DAWSON
  • 32 POSTS
This is verbatim from Mr. Compo. " I have got a second sensor from O'Reilly . It still had a crank no start. I will try again to exchange it for another one and try again. I hope it would be that simple. The truck started with the original sensor. When we had to take it out to change the clutch is when the mounting bracket came apart. I assume the plastic cracking and breaking is why Dodge changed to a metal mounting bracket. After we finished the clutch and installed the new sensor is when our crank no start came to be. I have been chasing my tail trying to track down this problem and am pretty much right where it started. I have ran every diagnostic I can with the truck not running. My Snap On machine only says cannot connect to PCM And most of the tests are supposed to be with the truck running. So my options are limited." Received 06/07/2018 at 1800 hours from Mr. Compo.
Jun 7, 2018 at 10:07 AM
STEVE W.
  • 15,413 POSTS
Not connecting to the PCM is not a good thing. Unplug the crank sensor and see if it connects, a bad one can stop it from operating.
Jun 7, 2018 at 11:13 AM
CARADIODOC
  • 34,414 POSTS
This is going on too long. Before you get more wrapped around the axle with confusion, stop everything and find a mechanic with a Chrysler DRB3 scanner. With an extra plug-in card, they will do emissions-related stuff on every brand of car sold in the U.S. starting with 1996 models, so a lot of independent shops bought them. The dealer will have a couple of them too, but they started becoming obsolete on a few 2004 models, and all models by 2009, so the dealer's will be packed away. I have my own to use on all of my vehicles.
This scanner lists the crankshaft position sensor and the camshaft position sensor under the "Inputs/Outputs" menu with a "No" or "Present" during cranking to denote whether their signals are showing up at the Engine Computer. At this point we are all assuming the cause of the no-start is the crank sensor, and no other tests have been done. This scanner also has a "No Start" menu that lists the exact reason the Engine Computer is unhappy and it will verify the automatic shutdown, (ASD) relay is not being turned on. If you should find the ASD relay is being turned on during cranking, that would prove the crank sensor is working and we have to look at the other possible causes of the no start.
A lot of independent shops are now using one of Snapon's scanners for newer vehicles. I bought one of those for my newer truck, but I have not bought the adapter cables for my older vehicles yet, so I do not know if that will show those two sensors or how their status during cranking is displayed. I am recommending the DRB3 for this because I know how it works for this type of problem.
Jun 7, 2018 at 2:52 PM
EDWINA F DAWSON
  • 32 POSTS
Gave information to Mr. Compo, the mechanic. Am waiting for his response/results. Will let you know one way or the other.
Jun 11, 2018 at 8:26 AM
EDWINA F DAWSON
  • 32 POSTS
Just heard from the mechanic. They do not have the "machines" you recommend using to analyze the truck and it seems like there are not many around here who do. Oklahoma City, Oklahoma even know what we are talking about? Advise?
Jun 11, 2018 at 9:02 AM
STEVE W.
  • 15,413 POSTS
Not surprising, many independent shops use third party test equipment if they do not do a lot of one particular make simply because of the cost of buying each specific tool.
As I said, if it is the wrong or shorted sensor and it cannot connect to the PCM, unplug the crankshaft sensor, as a bad one will stop the PCM from communicating. If you can now connect then there is either something wrong in the wiring harness or the sensor itself.
Jun 11, 2018 at 12:18 PM
EDWINA F DAWSON
  • 32 POSTS
Understood. It does not make sense to me that the only thing that happened was the clutch went out. Truck was running great before that. I agree about the sensor . A friend gave me the numbers of where he takes his Dodge duelly so we shall see if we luck out.. I will let you know.
Jun 11, 2018 at 1:21 PM
EDWINA F DAWSON
  • 32 POSTS
We are still searching for a facility which has the equipment you recommended. So far they do not. What is next?
Jun 13, 2018 at 3:02 AM
STEVE W.
  • 15,413 POSTS
Maybe go and get a cheap code reader or have him try a different scan tool and see it it will communicate. If neither one will and they work on other vehicles then it is time to work backwards. If the only parts changed were the flywheel and crank sensor and now it does not run, it is either they are not correct for that engine or there is an issue in the sensor or wiring. Or there is a problem with one of the other sensors that they needed to move when pulling the transmission. Like an O2 sensor harness shorted or a ground not attached.
Something that is easy to overlook when you get frustrated.
Jun 13, 2018 at 5:00 AM
EDWINA F DAWSON
  • 32 POSTS
Will let Mr. Compo know. As of today he is waiting for delivery of a new sensor.
Jun 18, 2018 at 3:24 AM
EDWINA F DAWSON
  • 32 POSTS
Well, still no start, but, the latest is (per one parts house) that CPS is obsolete. No longer available. For real?
Jun 27, 2018 at 11:04 AM
  • 55,721 POSTS
We are missing something here, does the engine have compression? if so spark and you can hear the fuel pump in the tank prime for five seconds?
Has Mr Compo tested the wiring harness for connection power and ground. If not I think that.
Has the ASD relay been checked?
Check out the diagrams (below). Please let us know what you find.
Cheers, Ken
Jun 28, 2018 at 4:59 AM
EDWINA F DAWSON
  • 32 POSTS
I should be hearing from Mr. Compo later this week. I will forward information to him. Thanks for all the help given. I have helped former husband with repairs to older vehicles but with computers running our vehicles may be a nice advantage they are also a nightmare. Will definitely keep you posted. New sensor finally did get here and Mr. Compo will be working on it this week. So we shall see. EFDawson
Jun 28, 2018 at 6:06 AM
EDWINA F DAWSON
  • 32 POSTS
New sensor number four will be in tomorrow. New sensor number three he tried today and still nothing. Again, I will let you know.
Jun 28, 2018 at 11:35 AM
STEVE W.
  • 15,413 POSTS
The only real way to test this is going to be to put a scope on it and see what signal the flywheel/sensor combination is sending, if any. An older analog voltmeter might show the activation of the sensor if he connect the leads to ground and taps into the sensor signal feed to the ECM. Then with power on but disconnect fuel and ignition and bar the engine over. There should be pulses in the same order as the old flywheel. 1-2-1-2-1-2 etc...
If you are getting those pulses at the ECM connector the problem is not the flywheel or sensor. Another item to check would be to put a piece of clay/gum/poster tack on the end of the sensor, dab a bit of oil on the end and place it in the hole to make sure the sensor air gap and flywheel tone ring are in the correct location. If the gap it excessive you get no signal or if the ring is not in position you get no signal.
Jun 29, 2018 at 8:34 AM
