Engine upgrade or swap
70,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
BALOO MCFLY
Looking to get more power out of my car listed above trying to figure out are there any double hump heads that are compatible with the 425 or should I just swap for a 500 or 472 if possible?
Apr 20, 2022 at 11:43 PM
STEVE W.
  • 15,411 POSTS
Pretty much all of those are high torque low HP engines built to move land barges. None of them have real potential for HP without a good amount of work. With a good cam, intake, headers and some good tuning on a Holley the best I've heard on the 500 was around 400hp. Spend a lot more and you can get more HP but by then you have replaced pretty much everything but the block.
If you want to dig a bit try:
https://cadillacspeedshop.com/
Most of the parts work on all of the big Cad engines 368, 425, 472, 500 but none of them live long past about 4,500-5,000 RPMs without adding big money.
Apr 21, 2022 at 12:36 AM
