Engine temperature gauge is inoperable?
68,000 MILES • 2.9L • 6 CYL • 2WD • AUTOMATIC
RICK WILLHITE
  • 5 POSTS
My temperature gauge is inoperable. I tested the sensor, and it is good. Is there a fuse or frangible wire I can check? I've seen a partial wiring diagram on-line that shows an inline device marked 1 and labeled C105, but do not know what it indicates. What else am I missing?
Jan 18, 2025 at 2:40 AM
  • 55,721 POSTS
There is just a blk/lb wire that goes from the sender to the cluster, so I would do a continuity test on that wire and if good replace the cluster with a rebuilt/used unit.
This guide will help with the test:
Here is the wiring diagrams for the coolant temperature sender so you can see how the system works. Check out the images (below). Please let us know what happens.
Jan 18, 2025 at 5:25 AM
