Engine temperature gauge reading consistently cold
100,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
TRENTDUPE
I noticed my truck was running very cold. The heater works fine, but the engine temperature only ever gets up to about 1/4 hot at the highest. I replaced the engine temperature sensor above the thermostat but that didn't fix the problem. I noticed that when I changed my coolant and was trying to get air out of the system, once I topped off the radiator no more fluid got sucked in from the radiator even though it was running for 15-20 minutes. The temperature gauge was still reading cold. I'm wondering if maybe the thermostat is stuck open? I don't know what else to try and don't want to do any damage to the truck. Please let me know if you have any suggestions? Thanks!
May 2, 2020 at 10:22 AM
  • 110,248 POSTS
Is the heater working now? I ask because if there is air in the system, that is the first place you will notice an issue. Also, is the heater putting out hot air?
Now, chances are you are correct regarding the thermostat. Since it was showing 1/4 of the way on the temperature gauge, that indicates it is working. So, the next step is the thermostat. Here are general directions for thermostat replacement:
Here are directions specific to your vehicle. The attached pics correlate with the directions.
____________________________________________________
2001 Ford Truck Ranger 4WD V6-4.0L VIN E
Procedures
Vehicle Engine, Cooling and Exhaust Cooling System Thermostat Service and Repair Procedures
PROCEDURES
Thermostat
Removal and Installation
1. Drain the engine cooling system.
2. Remove the air cleaner outlet tube.
3. Remove the generator wiring harness bracket nut and position the wiring harness aside.
pic 1
4. Disconnect the upper radiator hose.
pic 2
5. Remove the bolts, water outlet adapter, and thermostat.
- Inspect the O-ring seal, install a new O-ring seal if necessary.
pic 3
6. To install, reverse the removal procedure.
May 2, 2020 at 12:04 PM
TRENTDUPE
The heater is working and putting out hot air. I'm wondering if I should also replace the second sensor behind the thermostat housing. I'm hoping that swapping out the old thermostat will fix the problem completely. Thanks for getting back to me, I really appreciate your input!
May 2, 2020 at 12:40 PM
  • 110,248 POSTS
There are two coolant temperature sensors on this engine. One is for the gauge and the other is for the computer. I attached a pic. Let me know if that is the one you replaced.
May 2, 2020 at 2:50 PM
TRENTDUPE
Hi Joe! Looking at the engine from the front of the car I replaced the sensor further to the right on the drivers side. If that picture is the same orientation I would say I replaced the one not highlighted, I believe it was the one to the gauge but I could be wrong.
May 3, 2020 at 12:01 AM
  • 110,248 POSTS
The pic is from the front. I believe you replaced the wrong sensor. Do you still have the one you removed? I would switch it with the new on on the truck and then put the new one in the place indicated above.
May 3, 2020 at 1:00 PM
