Hard starting
2005 MAZDA 2
HAMDI HS
My mazda 2 problem is difficult to start the engine.. Ok,every morning i can start the engine as normal. No long crank.. when the engine hot after driving for a long journey/time,i stopped the engine for a stopby or shopping,after 15minute + i want to start the engine,its takes long crank to start and its takes more than 5 second to start the engine. but when the engine stil hot after driving i stop the car less than 5minutes then i start back,its no problem. the engine can start faster... so what the problem??
Apr 21, 2013 at 5:06 PM
It sounds like you may have a fuel pump going out but o be sure here is a guide to help walk you though the easy hard starting issues.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Please run down this guide and report back. Roy
Apr 21, 2013 at 7:33 PM
SHARIQ
Thank you for this post I had a vacuum leak causing my problem found it thanks to the guide. I love this site.
Feb 27, 2019 at 11:01 AM
