engine starts with high rpm
78,000 MILES • 1.4L • 4 CYL • FWD • MANUAL
ADIRO
Hi there, since last week or so, in the morning my car starts up with high rpm's 1500-1600, after one minute it drops down to 1000-1100 for few minutes and finally arrives at 800 rpm. I wonder what went wrong, there's no warning lights on?
Mar 18, 2016 at 12:27 PM
CAR-MAN145
  • 321 POSTS
This is controlled by the ECM the RPM is higher when colder and as it warms it goes down. If you think there is a problem then I would think it would be with the coolant temperature sensor, but if the idle goes down after a short time then I would think it is normal.
Mar 19, 2016 at 12:21 AM
ADIRO
as a new car it used to start up at 1000-1100 rpm shortly it dropped 700-800, now it is up to 1600 rpm and it takes much longer to reach the 800 rpm level, however you are right, I just noticed that coolant level is low, I'll bring it to correct level and see what happens. I will keep you informed. Thanks for your help.
Mar 19, 2016 at 2:27 AM
  • 55,710 POSTS
Did adding coolant help, do you have a coolant leak?
Mar 19, 2016 at 2:31 PM
ADIRO
it was a bit low, but not under minimum level
Mar 19, 2016 at 11:22 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides with choke cleaner and look for a vacuum leak maybe
Mar 20, 2016 at 8:20 AM
