Driving, running fine, started skipping bad, had to pump gas to get home, about four blocks. Since, replaced plugs, plug wire, coil. Still the same. It will crank and given gas, it will run with some skip, let off gas, it will cut off. Mechanic thinks could be jumped timing, another thinks wiring harness damaged from heat. thank you for your time.
Nov 30, 2017 at 12:11 AM
