Engine shut off while driving will not start
80,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
RUSTY61
  • 12 POSTS
I put a new cam and crank positioning sensors on my car because it shutdown on me. After I put them on it started up, it ran a little at first then smoothed out. I let it warm up some it seemed okay. Before I replaced the sensors the check engine light was on, but it ran fine. After I replaced the sensors, the light went out. I drove it down the road and it did the same thing. The engine shut down and wouldn't start, it acts like it's not getting gas. It has gas in it. I really don't know what to do. If you have an idea as to what the problem might be, I would grateful for any suggestions. Thank you.
May 27, 2022 at 10:53 AM
Sounds like we could have a failing fuel pump.
Let's start with checking the codes and see if that code that turned the light on is still there. Could have been corrected by the sensor as I think you are suspecting due to it turning off, but it may be related still. This is always the best place to start so here is a guide that will help:
Here are a couple of guides that will help with this issue as well:
https://www.2carpros.com/articles/car-not-running-advanced
However, after the codes we should check the fuel pressure and see if this is a fuel issue. If not, then we need to check for spark.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Once we know codes, fuel pressure, and if we have spark, then we will have a pretty good idea what the issue is or the direction to go.
Thanks
May 28, 2022 at 11:42 AM
