Based on your description, it could be a few things. The smell is from the catalytic converter. The amount of sulfur that is present in the fuel and can be a symptom of a bad catalytic converter. Additionally, if the engine is running too hot, it can happen, or more often, a bad fuel pressure regulator which is allowing too much fuel to enter the engine because it no longer reduces the pressure from the fuel pump.
With that being said, I would recommend starting with a fuel pressure test. Here are directions which show how to check pressure as well as a regulator. It is not hard, but requires a fuel pressure gauge. Most parts stores will lend you one.
The first picture I attached contains the pressure your vehicle should have.
If you find that the pressure is correct and within the manufacturer's specifications, the I recommend checking the catalytic converter. Follow the directions in this link:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter';
Here is a link which describes symptoms of a bad converter:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
In addition to the aforementioned suggestions, make sure the engine is running at normal operating temperatures. If it is overheating, that too can cause that smell.
Jul 19, 2018 at 1:16 PM
