Unfortunately, the engine code has to match in order for it to be a suitable replacement. The issue is the code will determine how the other components function and the computers will be different.
So, finding the engine with the correct code is necessary.
Also, you have listed the vehicle to have a 1.9L engine, on 2009 there were no 1.9L for the Jetta's.
SPONSORED LINKS
Friday, March 18th, 2022 AT 3:25 PM
