Engine problems
100,000 MILES
PSHAAS
After starting my car it performs perfect for 3 minutes then looses power. But if turned off then back on its fine for another 3 minutes. Had a diagnostic done and 8 problems showed up. Failed fuel injector for all four cylinders, failed Air injector pump relay, failed air solenoid valve, failed coolant temp sensor, failed leak detection pump. The spark plugs are heavily coated with a white powder as well. What component could cause all this to happen at once?
Apr 26, 2013 at 12:24 PM
we need the code numbers.
codes never identify bad parts, just failed systems
Apr 26, 2013 at 12:57 PM
PSHAAS
Here are the codes p1421, p1255, p1225,p1240, p1216, p1472, p1451
Apr 27, 2013 at 6:12 AM
EXOVCDS
  • 1,882 POSTS
Replace the fuel pump relay.
Thomas
Apr 28, 2013 at 6:26 AM
