engine jumping in bay during acceleration
217,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
SHAWN SPENCER
sitting in neutral my car runs perfect and can rev through all ranges in stride.
i put the car in first and go to accelerate the car needs to have the clutch feathered a large amount cannot let it out more than about 50%.
If i give it very slow throttle and work the clutch i can get out of first then have to do it again with second then third i can let the clutch out fully and forth i can shift into with no issues at all.
but going up hill or over bumps or letting the engine hit 3000 rpm with my foot off the clutch the engine starts jumping again.
i replaced the rear engine mount thinking that was the issue could the front mount be bad and is why it is still acting this way?
my thinking was that when the rear mount gave out the jumping of the motor was to much for the front mount and ruined it as well.
Jul 18, 2016 at 11:53 AM
JOHNNY G.JR
  • 320 POSTS
Motor mounts and or transmission mounts are possibly worn out. Are there noises associated with this issue?
Jul 18, 2016 at 2:42 PM
RIVERMIKERAT
  • 6,106 POSTS
What happens if you do not feather the clutch?
Jul 19, 2016 at 4:15 AM
RIVERMIKERAT
  • 6,106 POSTS
What do you mean by "the engine starts jumping."?
Vibrations that occur at specific speeds can be attributed to parts out of balance, either in the transmission or the wheels.
Jul 19, 2016 at 4:17 AM
SHAWN SPENCER
by the motor starts jumping i mean it you can actually feel the motor being thrown back and forth in the bay so hard that it bounces you out of your seat and thats what the motor does if you don't keep adjusting the clutch to keep the motor happy someone told me the maf is the standard cause for this issue on these motors
Jul 19, 2016 at 9:10 AM
  • 31,937 POSTS
I would be checking engine and transmission mounts if the engine is moving so much.
Jul 21, 2016 at 7:08 PM
