1995 Volkswagen Golf Miss and jerks
SHARKIVAN
  • 1995 VOLKSWAGEN GOLF
Engine Mechanical problem
1995 Volkswagen Golf 4 cyl Front Wheel Drive Manual 143000km miles
Hi carpros, my golf mk3, 1.8 gts, carburatored has a problem. When I start it, it swings n starts but doesnt hold da rev, it cuts off, then I start again and I hold accelartor down for about 5 minutes and release it, it idles ok. But once I start driving the car jerks while in motion even travelling at 100km it has da jerking. Please help me out, thanks
Monday, March 8th, 2010 AT 12:56 AM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Monday, March 8th, 2010 AT 11:33 PM
