engine problem
2009 TOYOTA
120 MILES • 4.0L • V6 • 4WD • MANUAL
AHMADALSHATTI
Here is problem:
1- sometime i hear knock sound if drive car from 0 mph with second gear
2- if i press brake pedal, rpm's idle drop down to 400.
3- sometime my engine shake quick just one second (look like you turn the key off and you turn on quick)
but this three problems does not always happen only once a day.
4- my car become very slow and no torque hard to reach 80 mph.
i do everything change (air filter, spark plugs, fuel filter) clean throttle body and clean fuel injection
but nothing changes still same problems.
thanks
Oct 4, 2016 at 9:19 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it . you may need an adapter for this which not sure they have. here is an article to help.
Oct 4, 2016 at 11:54 PM
