I have a problem with no power and no acceleration in high gear. it will not get above 2000 rpm's. I tried to do adjustment MAF. i also changed fuel filter and the problem got worse.
I do not know if this has anything do with MAF but the transmission will not downshift. I can pull the shifter into low and up shift fine no slip or any problems, but when I stop it stays in high gear until I manually shift it to low. once I start to move I can put the shifter in drive and shifts fine if I can get rpm's up. Please help.
Dec 23, 2016 at 12:56 PM
