what is the operating temperature for this vehicle and can it run too cool?
Mar 17, 2018 at 5:18 AM
MIKE H R
MEMBER
the operating temp should be about 180 degrees in temperature. If the engine is not getting hot I would look at the thermostat. If it is tuck open then the water {coolant will not have time to heat up} I come from a old school of thought and that is the first thing I would look at..
