Possible turbo is bad
53,000 MILES • 2.3L • 4 CYL • TURBO • 2WD • MANUAL
JASON CARDWELL
Exhaust started to smoke, no oil in car. have been told the impeller in turbo has excessive play. is this likely to be cause of oil loss?
Jul 9, 2019 at 5:22 AM
SCGRANTURISMO
  • 4,897 POSTS
If you have excessive blue smoke pouring out of your exhaust and you suspect it's the turbo then it is probably your output shaft seal that has failed. This could be caused by excessive play in your output shaft bearings(the high speed bearings).Turbos are fairly simple, they have an input shaft(which is driven by exhaust) with a large gear attached to it that drives a smaller gear attached to the output shaft which has a compressor wheel. It is the compressor wheel that compresses the air before it enters the engine's combustion chamber Each shaft is housed in the turbo body which shares the engines oil supply and each shaft has a lip seal to hold in the oil. The output shaft seal has probably failed. Please get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 9, 2019 at 3:59 PM
JASON CARDWELL
Thank you. exactly right just had a new turbo fitted by Mazda. keep up the good work .
Jul 20, 2019 at 3:00 AM
  • 55,711 POSTS
SCWICKEDSTANG is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Jul 22, 2019 at 11:38 AM
