Engine oil
42,000 MILES • 3.6L • 6 CYL • FWD • AUTOMATIC
PAPET
  • 105 POSTS
I have been using semi synthetic oil for the past six months and I am planning to switch to full synthetic oil. But I have one question, is it true that by switching to full synthetic oil will damage the gaskets and seals? Thanks a lot.
Feb 1, 2017 at 2:46 AM
HMAC300
  • 48,601 POSTS
no, it will not hurt them at all. semi synthetic is only 1/4 synthetic oil. you may see some oil usage at first oil change due to mineral oil working its way out, but that is normal.
Feb 1, 2017 at 4:18 AM
PAPET
  • 105 POSTS
So how many kilometers in between every oil changes of synthetic oil? And thank you very much for your reply.
Feb 1, 2017 at 4:57 AM
SATURNTECH9
  • 30,868 POSTS
8,000 kilometers if you burn oil inbetween oil changes you will burn even more oil with synthetic oil.
Feb 2, 2017 at 10:59 PM
