Own a 2003 Toyota corolla....Didn't know had bad oil leak drove it, started knocking, then shut down and wouldn't start.. Brought it home and broke the motor free (flywheel was stuck so I cranked on it with a breaker ratchet, popped started spinning again). Started the car horrible knocking noise was only started long enough to pull into my back yard then instantly shut off. Got under it found the rod bearings were complete toast so I replaced them and torqued them to spec (15lbs and 90deg turn..i do believe that's what it is) while I was doing so the rod closest to the transmission went a little to high so I had to remove the plugs and use a dowel to move the rod back down.. was super happy thought it was fixed went to start my car now it wont even start without being force fed gas...not to sure why with old broken bearings it ran, sounded like crap but ran and with new parts it doesn't even think about starting.. It gets gas all the way to the fuel injectors, just will not fire please help
Feb 9, 2016 at 7:35 AM
