Engine does not start?
110,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
IAKOVOS L. STYLIANOU
  • 8 POSTS
engine start no running. i clean the nozzle ok. the spark pluck have ignition.
Nov 5, 2022 at 1:09 AM
  • 110,248 POSTS
If you have spark at the plugs, then it must be a fuel-related issue or a timing issue. Try this. See if it starts for a couple of seconds using starting fluid. If it does and then stalls, we know its fuel related.
Also, if you can record it cranking and upload it for me to hear, I should be able to tell if it is a timing-related issue.
Note: Please confirm the engine size. In 2007, only a 2.0L and a 2.4L were offered.
Nov 5, 2022 at 3:10 PM
  • 8 POSTS
Thanks Joe, what do you think for Camshaft position sensor?
Nov 6, 2022 at 1:57 AM
  • 8 POSTS
the engine is 1388cc 2007.
Nov 6, 2022 at 1:58 AM
  • 110,248 POSTS
Anything is possible. However, before replacing parts, we need to determine the cause. By chance, did you see if it starts with starting fluid?
Also, are you located in the US? I ask because the engine you indicated wasn't offered. If you are in a different country, that could be the reason.
Nov 6, 2022 at 11:15 AM
  • 8 POSTS
Have a good day. I just bought this car at the auction, and I just picked it up now and it has no compression. Has anyone changed the timing belt in 2019 and since then the car has idled, what do you think, could the valves have gone wrong?
Nov 9, 2022 at 2:39 AM
  • 8 POSTS
Hi Joe!
I live in Cyprus.
Nov 9, 2022 at 4:46 AM
  • 8 POSTS
I have taken the injectors out and started and the injectors are working normally.
Nov 9, 2022 at 4:50 AM
  • 110,248 POSTS
That explains why I can't find the correct engine. You have spark and fuel, so I need to confirm what you said above. Does it have compression? Can you record it cranking and upload it for me to hear?
Nov 9, 2022 at 9:03 AM
  • 8 POSTS
Hi Joe,
Nothing compression this is mysterious.
i make video tomorrow.
Nov 9, 2022 at 5:53 PM
  • 110,248 POSTS
If you have no compression, the timing belt may have failed. If the engine is a 1.4L., I can't even find information on it to determine if it is an interference engine.
I will watch for your video. I'm interested in hearing what it's doing.
Nov 10, 2022 at 10:47 AM
  • 8 POSTS
Thanks Joe!
See you soon, have a good day.
Nov 12, 2022 at 12:35 AM
