Engine misfire, loss of power and shuts off
216,025 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
KAOMA
  • 24 POSTS
The vehicle runs a little smooth when idling, but the engine misfires very bad when load is applied i.e., A/C on or gear is engaged, it shuts off while driving, at times it hesitates when accelerating, sometimes it drives nicely that you can drive 5 kilometers without having any of the problems mentioned above, when it shuts off while driving it starts right back up and drive for a kilometer or 2 then shuts down and start again, sometimes it hesitates to start but eventually starts back up.
History of the car: last year in May we changed the valves as it had broken most of them, this was because of a mis-timing after changing the crack shaft pulley, it was correctly timed after changing the valves and worked just fine, In October the transmission got damaged and the car was parked until January this year, we changed the transmission 2 weeks ago, the transmission runs smooth and changes gears without any issues.
The engine misfire and loss of power started after the car got started after being parked for a few months, i was told to replace the fuel pump and filter which was done, i replaced the spark plugs but this has not solved the problem. The car does not have an engine light on, a diagnosis machine was connected to the car and did not bring any codes or faults.
The mechanic insists that this is a mechanical problem and that there are some valves that might not be closing completely hence the misfire and loss of power.
The mechanic says we need to re-time (timing) valves again. i am a little hesitant to go along with this. my vehicle uses a timing chain (not timing belt).
Could the mechanic be right and re-timing will solve the problem or what could really be the problem causing the engine misfire and loss of power?
Your quick response will be highly appreciated
Thank you,
Kaoma.
Feb 14, 2022 at 2:26 PM
KAOMA
  • 24 POSTS
Hi, I forgot to mention one thing. When the engine loses power and is about to shut down while driving it also makes pop sounds on the exhaust as you try to accelerate or rev the engine.
Feb 14, 2022 at 2:48 PM
  • 110,244 POSTS
This could be the result of several things. For example, a plugged catalytic converter, engine timing, engine vacuum leaks, air/fuel mixture, and so on.
The easiest thing to start with would be simply checking for vacuum leaks. Here is a link that shows how it's done:
Also, I need you to pay attention to something. When this starts to happen, is there any black smoke from the exhaust?
If there are no vacuum leaks, smoke, or indication there could be a plugged exhaust, then I would recommend doing a compression test. This will help determine if there are valves leaking or if the timing is off. Here is a link showing how that is done:
I don't know if these things have already been checked, so let me know. Also, let me know the results.
Feb 15, 2022 at 8:55 AM
KAOMA
  • 24 POSTS
Hi Joe, thank you, i will give you feedback as soon as these tests are done.
Thank you,
Kaoma
Feb 15, 2022 at 2:35 PM
  • 110,244 POSTS
You are very welcome. I will watch for your reply.
Feb 16, 2022 at 7:39 AM
KAOMA
  • 24 POSTS
Hi Joe, we changed the fuel pump, and the misfiring is no more, now just a bit of jerking. I will keep you posted.
Feb 17, 2022 at 4:38 AM
  • 110,244 POSTS
It sounds like the pressure was low causing a lean fuel mixture. Keep in mind, if you had the battery disconnected, the vehicle will require a short period of time to relearn settings and run normally.
Let me know if it changes.
Take care and thanks for the update,
Feb 17, 2022 at 7:19 AM
