Engine knocking on the front of the engine that gets faster when accelerating?
102,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
LOGANM1031
The noise stops after 3rd gear, my car jerks back and forth if I hit the gas too hard. There's a really bad smell coming from my engine, and my tensioner pulley is squeaking.
Sep 26, 2022 at 7:05 PM
  • 55,731 POSTS
It sounds like you might have a rod bearing, cracked piston or a blown handbasket between two cylinders. Can you please shoot a quick video with your phone so I can hear the engine noise? That way I can tell for sure what's going on. You can upload it here with your response. We can start by doing a compression test. This guide can help you:
Please go over this guide and report back. As far as the "tensioner pulley is squeaking" please start another question, we handle one problem per thread.
Sep 27, 2022 at 4:09 AM
