engine knock
100,000 MILES • 5.0L • 5 CYL • 4WD • AUTOMATIC
NICKNOCELLA22
  • 35 POSTS
so as i start my truck up this just started to happen as i start my truck there is like 3 knocks then it goes away i put in lucas oil heavy duty stabalizer fixed it for a day and its back at start up and as a rev it when the rpms go up you can hear the knock sounds like lifter knock idk mabye ill try marvel mystery oil
Jan 10, 2021 at 3:21 PM
Good morning,
Can you upload a video of the noise so I can hear it?
https://www.2carpros.com/articles/engine-noises
Jan 10, 2021 at 8:03 PM
NICKNOCELLA22
  • 35 POSTS
There’s that as I rev the RPMs up it goes higher and higher and you can hear it more. my buddy said lifter knock. I don't know. I tried using Lucas oil heavy stabilizer worked for a day then came back. I was going to try Marvel Mystery Oil next oil change to see. Please help.
Jan 11, 2021 at 5:46 AM
Okay, thanks.
That noise is lifters. I would do a manual oil pressure test to be sure you have the correct pressure to the top of the motor for the lifters.
None of those additives have any effect on noises.
If the pressure is 20 at idle and 40 at 1,500 RPMs, then you need a set of lifters.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Jan 11, 2021 at 6:17 AM
NICKNOCELLA22
  • 35 POSTS
So if I put Marvel Mystery Oil in at next oil change it wouldn’t benefit it at all? Can I use it in my gas too to keep it clean or no?
Jan 11, 2021 at 6:25 AM
NICKNOCELLA22
  • 35 POSTS
Should I still put the Marvel Mystery Oil in crankcase at oil change just to clean it and my gas then to make it run good?
Jan 11, 2021 at 6:30 AM
Forget about the marvel mystery oil. It has little or no effect at all.
Check the oil pressure as I suggested.
Jan 11, 2021 at 6:40 AM
NICKNOCELLA22
  • 35 POSTS
What if I check the oil pressure and it’s normal but still makes noise?
Jan 11, 2021 at 7:00 AM
NICKNOCELLA22
  • 35 POSTS
So what should the pressure be at when I test it?
Jan 11, 2021 at 10:09 AM
I posted the specs a couple of posts back.
Idle should be 20 pounds. At 1500 it should be 40 pounds.
If the readings are good then you will need a set of lifters.
Can you tell me if you have the pushrod motor or overhead cam engine?
Jan 11, 2021 at 11:47 AM
NICKNOCELLA22
  • 35 POSTS
So if the readings are at that number then I need lifters. I do not know what kind of motor. it’s a 2011 F150 8 cylinder 5.0 if that helps isn’t if it’s at those numbers then there fine or no.
Jan 11, 2021 at 3:59 PM
Can you give me the complete VIN number?
Jan 11, 2021 at 7:22 PM
NICKNOCELLA22
  • 35 POSTS
Yea should I test the oil pressure or no have a shop do it?
Jan 12, 2021 at 4:23 AM
You can do the test yourself but if you never did this. it would be better to have a shop perform it.
You need to remove the oil pressure sensor and install the manual gauge.
Engine Oil Pressure (EOP) Switch
Material
Item Specification
Motorcraft® Thread Sealant with PTFE
TA-24-B WSK-M2G350-A2
Removal
4x2 vehicles
With the vehicle in NEUTRAL, position it on a hoist. Refer to Section 100-02 .
4x4 vehicles
Remove the generator. Refer to Section 414-00 .
All vehicles
Disconnect the EOP switch electrical connector.
Remove the EOP switch.
Installation
All vehicles
NOTE: If the oil pressure switch is to be reused, apply thread sealant.
Install the EOP switch.
Tighten in 2 stages.
Stage 1: Tighten to 14 Nm (124 lb-in).
Stage 2: Tighten an additional 180 degrees.
Connect the EOP switch electrical connector.
4x4 vehicles
Install the generator. Refer to Section 414-00 .
Jan 12, 2021 at 6:32 AM
NICKNOCELLA22
  • 35 POSTS
I don’t know what that all means. I’m not that familiar with these trucks, so what do I tell the shop that I need to have looked at then?
Jan 12, 2021 at 7:10 AM
NICKNOCELLA22
  • 35 POSTS
It’s getting worse.
Jan 12, 2021 at 7:11 AM
Just ask them to check the oil pressure with a manual gauge.
Jan 12, 2021 at 7:20 AM
NICKNOCELLA22
  • 35 POSTS
This is different topic but what’s the best oil for my truck? I used blend before but what's the best for these engines with 100,000 miles?
Jan 12, 2021 at 8:00 AM
I attached the recommendation below. No additives of any kind.
Jan 12, 2021 at 8:14 AM
NICKNOCELLA22
  • 35 POSTS
Do I need to use Motorcraft?
Jan 12, 2021 at 4:17 PM
NICKNOCELLA22
  • 35 POSTS
I read that Marvel Mystery Oil helps clean everything, but I can’t find that oil around any stores by me. so like what brand is good besides that Mobil or Castrol or something? can I use full synthetic or no?
Jan 12, 2021 at 4:18 PM
I would use the Mobil one fully synthetic for maximum protection.
Again, no, forget about the Marvel oil. It does nothing for you. The oil has all the additives you need.
Jan 12, 2021 at 5:35 PM
NICKNOCELLA22
  • 35 POSTS
Alright, I will bring to your a shop to get that lifter issues sorted I do have a warranty.
Jan 13, 2021 at 5:15 AM
Sounds good.
Keep us updated.
Jan 13, 2021 at 5:18 AM
NICKNOCELLA22
  • 35 POSTS
So, I just say I hear a lifter knock when I start it and when I rev it and as it downshifts going down a hill all you hear is knock loud and at idle loud?
Jan 13, 2021 at 5:19 AM
Tell them you have an engine noise and let them tell you the issue.
Jan 13, 2021 at 5:23 AM
NICKNOCELLA22
  • 35 POSTS
The dealer where I bought it the techs there are a bunch of retards they don’t know anything.
Jan 13, 2021 at 5:24 AM
If you have a warranty, try another dealer.
Jan 13, 2021 at 5:25 AM
NICKNOCELLA22
  • 35 POSTS
Also every time I drive and turn it feels like the tire shakes. I try to look at it but I can’t clearly see it but when I drive something on the front feels like it out of align.
Jan 13, 2021 at 5:27 AM
One thing at a time. Let us see what the issue is with the engine.
Jan 13, 2021 at 5:29 AM
NICKNOCELLA22
  • 35 POSTS
Alright.
Keep us updated.
Jan 13, 2021 at 5:30 AM
NICKNOCELLA22
  • 35 POSTS
Will do.
Jan 13, 2021 at 6:07 AM
NICKNOCELLA22
  • 35 POSTS
Is it bad to drive it with that knock until I can get it looked at?
Yes, I would not drive it as you may be doing internal damage to the motor. You need to have it checked as you may need a motor.
Jan 13, 2021 at 6:27 AM
NICKNOCELLA22
  • 35 POSTS
It’s my only transportation and I have work.
Jan 13, 2021 at 7:29 AM
I do not know what to tell you. Even when it is diagnosed, you will be without the truck until it is fixed.
Jan 13, 2021 at 8:07 AM
NICKNOCELLA22
  • 35 POSTS
I’m going to call tomorrow do you suggest I get the 100,000 service done for my truck while it’s there or fix the engine first?
Find out what is wrong with the engine first before doing anything.
Jan 13, 2021 at 8:10 AM
NICKNOCELLA22
  • 35 POSTS
Alright be in touch. I don't know if you are from the area I am. but is there a better way of contacting you?
Jan 13, 2021 at 8:14 AM
NICKNOCELLA22
  • 35 POSTS
Before I forget so my truck is the flex fuel one I just started using flex fuel gas. what other gas can I use in my tank because they don’t have flex fuel when I go home?
Jan 13, 2021 at 8:27 AM
