Engine knock
150,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ENZODEN
A friend of mine came to me with a very loud knock coming form the top engine around the 3rd cylinder (with engine above idle speed only). All the research I did told me it was a blown connecting rod. I did a full rebuild and found oil starved and slipped brngs. No other major damage. Crank shaft was fine, pistons were not cracked/broken (one piston was a little stiff), cam and bearngs were fine, some lifting rods were dry, but no damage. Cleaned and replaced everything as per a normal rebuild. I got the engine back together and installed in the van, fired right up and wouldn't you know the knock was still there. PLEASE HELP
Mar 14, 2016 at 7:16 AM
HMAC300
  • 48,601 POSTS
If the bearing spun the crank should been replaced as well as the rod depending on how damaged the rod is/was, also oil holes in block should have been checked for debris as there was probably debris in it.
Mar 14, 2016 at 9:10 AM
