Engine is hard starting
143,000 MILES • 5.7L • V8 • 2WD
PHILIP MOORE
The engine doesn't start easily as it once did. This is an erratic condition. Typically when the engine is cold it will start much easier than once it's warmed up.
At a cold start up it will start almost immediately. After the engine has been running virtually for any period of time it takes more than fifteen seconds to start.
The fuel filter, spark plugs, plug wires, air filter, have all been replaced. IAC sensor was cleaned. This didn't effect the issue. engine has 143,000 miles.
Jun 15, 2019 at 4:37 AM
Good afternoon,
Low fuel pressure is the most common reason for this.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
You need to check the fuel pressure when it is warm and is cranking for the time. My bet is you need a fuel pump.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Jun 15, 2019 at 5:30 AM
PHILIP MOORE
Thanks so much for your insight. I really enjoy the vehicle and am hoping to drive it a good bit longer with a new fuel pump.
Jun 16, 2019 at 10:24 PM
You are welcome.
Always glad to help.
Jun 16, 2019 at 11:48 PM
