Engine idles too low when warmed up
25,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
ROBERT COMMINOS
I live in Las Vegas and this generally only happens in the summer when it is very hot. I start the engine in the morning it idles high at 1,000 rpm's and then settles down to about six or 700. After I drive in a while, park it, then get back in and started up it wants to idle at around four 500 rpm's and if you put it under a load such is turn the steering wheel it wants to stall out and stumble a bit before you get underway. After you are underway it is no problem at all. Generally this is a problem in the summer heat. Not so much in the winter.
Jul 28, 2018 at 5:45 AM
  • 55,746 POSTS
This sounds like you have a vacuum leak. Here is a guide to help you see what is going on:
Cheers, Ken
Jul 29, 2018 at 9:23 AM
