1997 Jaguar XJ6 hard to turn when at slow or idle speed
1997 JAGUAR XJ6
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
TABBOTT13
when bralkng to turn corner, parking etc very difficult to steer. steerng fine when driving otherwisel
Oct 30, 2008 at 8:43 AM
  • 31,937 POSTS
Hi there,
Start with checking the power steering oil and the drive belt tension, if all is OK you will have to go to a dealer and get a system pressure check done as the pump pressure may be low, the reason the steering is better at speed is that it is a variable pressure system and the power steering cuts back at higher road speeds as it is not needed, if it did not do this the steering would be feather light at speed and that is not desired.
mark (mhpautos)
Oct 30, 2008 at 9:11 AM
